Swift Stabilizer Bars Reviewed
#31
Talking about the metal brackets that hold the poly bushings... OE ones suck. I killed two on the OE suspension. Then again, I was not kind. With higher rate springs, it might not be as much of an issue.
Sounds like they don't come with the upgraded brackets though
The Perrins are these: http://www.perrinperformance.com/pro...gory=8&model=3 Mucho solid compared to the dinky OE set.
I was looking at the full Perrin rear bar http://www.perrinperformance.com/pro...gory=8&model=3 until this thread.
#42
Can someone who has done this swap chime in with how much work it is. I had some big bars on my DSM and they were needed. So, I am tempted to go this route again.
#44
did you notice any understeer characteristics by upgrading the front sway bar (not taking in consideration of type of tires) or was it pretty balanced because of the rear sway bar, im just curious cause i here mixed feelings about the fsb upgrades?
