replacement brake pads
it's getting time i change my oem brake pads. i have done the research and it seems like hawk hps are the best bang for the $ (i don't have). i am deciding between the hps (HB453F.585 & HB180F.560) and the performance ceramic pads (HB453Z585 & HB180Z560). any thoughts? pls post asap so i can make decide once and for all.
any thoughts on other pads you think are better in this price range or cheaper (<$200)? pls let us know. thanks in advance!
thanks for the post. not heard much about ferodo. wish there was a way to compare these products head to head with their specs - coeff. fric, temp range, etc. then it would be easier to select a brand and type within the price you want.
I put the Hawk HPS pads all the way around on my Evo 2 weeks ago. I noticed an immediate increase in brake performance (better feel, shorter stopping distance) and a huge decrease in brake dust. I don't know if anyone else thinks the stock pads throw off a lot of dust, but it used to **** me off. I'm very pleased with what the HPS pads have done for my car, and will stick with them when it's time to swap em out again.
I have the Hawk HPS and they are working for me. I have about 330 HP and run a few HDPE's, and they seem to be holding up well. I'm also planning on getting cooling ducts which should help some too.
They only squeal right as I come to a slow stop, but not bad.
I know another guy who ran the HPS with a little more HP (but only a second less time) and they disintegrated.
So I guess it depends on how hard you plan on running them.
hope that helps
hope that helps
