Wheel Bearing gone bad already???
ok, finally had time to install the new wb. All and all it went good, the main wheel bolt was a pain in the @ss! But it did fix the problem thanks for the help fella's!
I know this thread is dead and has been dead for a while, but I came upon this and almost puked all over myself after seeing the awful advice that was posted. DO NOT EVER try to remove or install a wheel bearing with anything except a shop press. NO hammers, prybars, slide hammers, etc. If you try to do it this way (which even a shade tree mechanic knows not to do), you will risk ruining the bearing over again, risk having a "cockeyed" or crooked bearing causing your alignment to be skewed, and also will risk your life driving a car with a inproperly installed wheel bearing. Evo wheel bearings are not known to fail prematurely, except when some idiot kid slides off the road and hits a curb, and then promptly sells his car to an unsuspecting buyer. OK, rant is over.
1 Post
use a hammer son and hammer away that is when your removing it. Be careful when installing though, any sort of impact on the bearing could ruing it. I know from experience and so does my dad, LOL.
Make sure you get the pair might as well.
For installation, if you have to use anything other than hand force then something isn't quite right. As you just push in the new one and tighten up those 4 bolts.
Fair enough for press in type bearings, but for evos the bearing comes in a whole hub assembly, so to remove the old one you just undo 4 bolts then pop out the old assembly, sometime it quite rusted in there so this is where a slide hammer comes in handy.
Did anyone find out what the part number was on the front wheel bearing? And the price too? I called the dealer and he told me about $250.00, which seems a bit "dealerish" if you ask me. I looked on mitsubishiparts.net, but like it was said in the previous posts, it shows "w/out" turbo.
Whats what????
Whats what????
