Tein Super Street vs. Bilstein b6 in Poland
If you are keeping the rears then I would get the MR springs.
How many miles on the car? If over 50k, then I would change them both.
Thanks I will check and replay
You are right
My numbers:
Front F4-VE3-A900 TO
Mitsubishi nr MN 101890
I didn't check rear but I know that Mitsu nr is MN101899
Problem is that front right coilover is dead and I have to change it. OEM coilover costs 1000$ a-piece. It means 2000 $ per pair. I think i will change it for aftermarket b6 so GSR springs will be better option ? Should I change rears ?
You are right
My numbers:
And you have clunking from the front? Is it leaking fluid? Rides like you are on a waterbed?
I would replace both fronts. But I would consider doing the rear also. Since you are upgrading to the HD struts they will not be totally matched to work together now. Just my .02
I have the GSR set on my HDs. But the only difference is the rear springs have a lower start rate and a slightly lower highest rate. But I do track a bit more. So for the street you should have a nice combo. Add the Swift Stabilizer (sway) Bars and you will have a complete susp. setup
hatakashi
May 6, 2012 10:59 PM
ghoonk
Jul 25, 2007 06:53 AM
b6, bilstein, difference, evo, evo9, f4be5b844h0, f4ve3b843h0, flex, mitsubishi, performance, review, springs, ss, superstreet, tein, vs
