Which Brake Duct Cooling Kit for my EVO 8 ???
I'm in the process of installing one. If you are debating between the different kits, I would pay a lot of attention to the way the vents mount to the calipers. The Forge kit has machined spacers that ensure that the aluminum ducts don't function as crush washers under the caliper bolts. It reuses the stock washers together with the spacers to ensure that the calipers continue to be torqued with no aluminum in the equation. I'm not explaining this very clearly, but if you do a search, member "ez" did a post about this a while back. After installing the Forge vents this past weekend, I see exactly what he was talking about and why it's important to ensuring that the calipers stay securely mounted.
It may be a nice feature to have the duct floating and not sandwiched between the bolts and the caliper - but it's not a problem if it is.
The modulus of aluminum and steel can be very similar, so there will be no "crushing" unless there is actual geometry intended to deflect. It's not like aluminum is weak or squishy. And to add to that the coefficient of thermal expansion is higher for aluminum than steel. So as the parts get hot the torque on the bolts will actually increase.
The AMS parts are stainless steel just so you know. Which I don't know why. Stainless is a horrible conductor of heat and will end up storing heat compared to similar aluminum parts.
<<The AMS parts are stainless steel just so you know. Which I don't know why.>>
Probably stainless for rust resistance reasons. I went with the Forge system. It is now installed and will be tested this weekend at Watkins Glen.
l8r)
My point wasn't that my calipers are turning darker, it's that unlike my first set, they are changing color at different rates for the inside half of the caliper vs the outside half. The inside half is cooled by a brake duct (ghetto, homemade style), so I'm just wondering if that should be taken as a sign that the brake ducting is actually working.
l8r)
l8r)
Damn Rich, I have no idea how you didn't turn your calipers brown at VIR. Your car is much faster than mine and I turned mine almost brown in that one event. I was braking very late in some sections though I'm looking into brake ducts at this point as well and haven't decided wether or not I will build my own or buy some. AMS kit looks nice, as does the Forge kit
Keep in mind our system was used on our own time attack car....with GREAT results.
one nice point about out kit is not only do we give you a custom machined duct that directly diverts air into the Vein of the rotor but we also ditch the factory dust shield and replace them with a rust preventing, tighter fitting Stainless steel counter part....again custom machined here in house.
Lastly for you SCCA guys the AMS Brake cooling kit is the only SCCA T2 approved brake kit for The EVO VIII/IX
Eric
Eric
Eric
Eric
A properly functioning rotor will pull air from its center and exhaust it out the edges right? Especially aftermarket one with curved vanes.
By closing off the inside of the rotor, aren't you limiting air flow to what can come through the ducting (which is somewhat restrictive because of (1) the narrow slit that the air has to pass through between the caliper and the rotor center and (2) the relatively small 2" duct tubing), rather than letting the rotors inhale through both the ducting and the other air inside the wheels?
I'm no engineer and maybe I'm misunderstanding something fundamental, but I've always wondered this about the AMS ducting design.
Currently I have ghetto ducts which are simply hoses pointed in the general direction of the calipers and rotors. They work good enough that I've never had brake fade, and my calipers are still more red than brown.
But I'm building some aluminum ducts to mount directly to the calipers. Hoping to direct the airflow to the correct places and the aluminum structure of the ducts actually create a nice heat sink surface.
The whole idea of ducting is to increase airflow through the rotors. They are the most effective place to transfer heat as they have a large surface area. Directing air at the calipers will help keep them a little cooler, but when looking at the braking system overall, the best heat exchanger is the rotors.
What is the purpose of replacing the dust shield, especially with something that is tighter fitting?
l8r)
