front drives side tire balding on the outside??
ok well i noticed that my left front tire is balding on the (outside) and i dont drive hard witht he car. I brought it the my local mitsu. dealer and they said that the suspension has two settings, one of the settings was set to 1 the other was set on the second setting. just wanted to get more insight about the settings, and if anyone else had this problem.. all in all i got a four wheel alignment and new tires and they said i will be good to go.
The dealer was referring to the camber adjustment bolts. they have 2 settings ... -1º and -2º. If they were mis-matched you probably have some toe issues on that one wheel (at least). An alignment should correct the issue.
legendr34
14
Jan 16, 2014 08:45 PM
Nerologic
Sep 29, 2006 01:03 PM
