KW Variant 3 spring swap
Ok, newbie question. I want to change the front springs on the KW3's. Do I get a spring compressor, compress the spring and then undo the main nut at the top? Haven't dealt with coilovers before.
Thanks!
Thanks!
Absolutely correct. I just installed my Robi KWs this weekend (and I'll take the space here to say Robi is bar none the best vendor I could ever hope to deal with!) and can confirm you don't need a compressor. The only part that will be a little problematic is torquing down the top nut (32 N-m), as the actual coilover body will start to spin once the nut is threaded. I just used a pair of vice grips with paper towel in the teeth to hold the shaft - worked perfectly and left no teeth marks. You can also use something like a rubber fan belt (Robi's suggestion).
which top nuts are you referring to? The rears?
I'm referring to the fronts - the rears are very easy to do as the coilover body "catches" and stops rotating almost immediately, but the fronts will keep spinning. Robi informed me that the valving can be damaged if they spin too much.
fdryanaf
17
Feb 16, 2016 02:32 PM
DANRR05
26
Jan 29, 2010 02:39 PM
GTWORX.com
Evo 'For Sale' Suspension / Brakes / Handling
68
Jun 6, 2009 09:08 PM
jkim2001
22
Jul 14, 2008 12:54 PM
