Rotor issue..ok to swap rotrs and keep old pads?
Rotor issue..ok to swap rotors and keep old pads?
I was getting a slight squeek from my breaks and figured it was time for a change. I swapped out the pads for some new hawks about a week ago and since then the noise has grown louder by the day. It is not a constant, it gorws with speed and on the highwat it is just a high pitched squeel. The only thing I can think of is the lip that was formed on the outer edge of the rotor is hitting something inside the caliper. I do not think it is warped since there is no vibration in the steering wheel.
Is it ok to swap out just the rotors and keep the week old pads?
Any suggestions on rotors, I was going to get the Brembo slotted replacements. i am not certain how to do the wap either so if anyone has any advice and if I need certain tools please let me know.
By the way, I drive an Evo IX, not a WRX. the name is old.
Thanks.
Thanks.
Thanks for the input!
My main concern is if the pads will take on the shape of the current rotors and transfer any problems to the new rotors or will they just wear down and be fine.
you will be fine changing the rotors out but you have to watch with the hawk pads if you search on here there are hundreds of posts of people with brand new hawk pads that squeek uncontrollably i just put i set on my car and within a week i took them off because i couldnt stand the squeeking
You and I it sounds have had the same issues. I'm 100% sure that you need to change your rotors. The lip on your rotor is causin the noise even though you do have new pads, and also go ahead and use your hawk pads. 1 week will not hurt anything. My buddies evo had the same problem, I changed his pads and rotors and it was perfect. Good luck.
MJ23FE
28
Mar 11, 2012 12:54 PM
Iowa999
Aug 11, 2011 11:11 AM
EvolNinja
Nov 3, 2008 02:00 PM
x838nwy
Nov 29, 2005 10:21 PM
