Enkei rp03 17x9.5 +38mm fitment?
Im running 18x9.5 RP01 with a +38. With 275/35/18.
My Rotora Big Brake kit is about 2-3mm thicker than stock, which acts like a spacer.
Fronts, running with camber bolt on the more positive setting, no rubbing, but its close.
Rears, running 2 degrees negative camber, fenders with medium roll, rubs slightly only under heavy compression.
Well, I am in a similar predicament, I have 17x9.5 NT-03M's and 25mm H&R spacers up front as recommended by Kyle at Hotlap and the wheels stick out like a ****. The spacers were to help clear the megan coilovers and increase track, but I think a little too much. I am waiting to hear back from Kyle.
I have read of people running 20mm spacers with your wheel setup...
