Why the hell do I keep eating up frt wheel bearings?
Old Aug 12, 2008 | 03:44 AM
ACLdestroyer's Avatar
Suspensions is stock except for a rear sway.
First set died at 35k. Frt RH bearing is starting to die now again at 65k.
Any thoughts? Is this common on Evo IXs?
Old Aug 12, 2008 | 03:51 AM
Spish's Avatar
Mine wore the FR, took it to Mitsu, they changed it and said my left on was bad too and to come back and they would change it. I came back and now they are saying it's NOT my wheel bearing, they say my tires are "cupped", I've never seen cupped tires and mine look mint. Free bump.
Old Aug 12, 2008 | 05:30 AM
11secDSM's Avatar
Are you running aggressive offset wheels by chance?
Old Aug 12, 2008 | 08:47 AM
madmax199's Avatar
Low offset wheels and big spacers are the usual suspects with decreased life WB.
Not properly installing and removing your wheel studs could potentially be fatal to your bearings; hard hitting on the studs with a hammer can damage the bearing.
Old Aug 12, 2008 | 10:05 AM
kekek's Avatar
Improper installation may also be a factor. The spindle nut must be tight before the any load is applied on the wheel bearing.
I did have a friend autoxing an evo9 who had a wheel bearing die early on him. Probably similar mileage to yours. Perhaps it was a bad lot during production. They really aren't too hard to replace nor are they terribly expensive. In the $160-$170 range right now.
I recently had a drivetrain issue that I thought was a bad wheel bearing. Now I have a spare.
Old Aug 12, 2008 | 01:24 PM
Spish's Avatar
Mine is completly stock.
Old Aug 13, 2008 | 10:18 AM
Shadowpriest's Avatar
What is the sound you hear when you have a wheel bearing going bad? I've had a "popping" sound that comes from the front right of my Evo IX when taking off in first gear after coming to a stop. I've done figure eights in parking lots to the left and right and there is no popping at all (like if the diffs were going or the axle was bad). It only occurs when either at a stop or very slow speeds and I'm letting the clutch out in first gear, it's like a " pop-pop-pop" just for a second as I'm disengaging the clutch. Don't feel anything in the clutch or steering wheel when it's happening, just a noise from the front right.
Old Aug 15, 2008 | 10:02 PM
migs647's Avatar
EvoM Community Team
I'm also interested in what you're hearing. I'm getting a wobble (almost sounds tire) that is intensified in both corners.... high speed corners (40+). I've also been hearing a pop as well. I'm hoping they are related.
Old Aug 16, 2008 | 06:43 AM
Smike's Avatar
Whats the part number for the bearing. And isnt it a bear/hub combo?
I am about to take off the front corners to do a clutch job (x2). We found all the bolts stuck, but I am pretty sure a bearing if toast too.
Old Aug 17, 2008 | 08:28 PM
SpeedJunkyz's Avatar
+2 on sound......i am getting a very agressive grinding, popping, clunking sound when slowing down and only at around 1k rpm.....slight popping, clicking when pulling off to the left or right.......is this an easy fix?
SJ
Old Aug 17, 2008 | 08:43 PM
migs647's Avatar
EvoM Community Team
Is the grinding speed sensitive
Old Aug 17, 2008 | 08:45 PM
yeah goes away with speed......but i can very faintly feel popping when i have the feet on the floor board when in higher speeds....so faint i would almost say its not there......
sorry I didnt mean to jack the thread......felt that we had similar problems, figured we could learned together haha
My pass. fender gets extremely hot aswell...could this be a factor?
ChadB
Feb 11, 2012 09:22 AM
Sanny632
Sep 20, 2011 02:30 PM
tsi20gawd
Northwest Region
Jun 22, 2010 04:23 PM
colburn22
For Sale - Cars For Sale
11
Jul 16, 2009 05:40 AM
the X
15
Mar 27, 2005 04:27 PM
