Popping noise when turning wheel with swift springs
I need help. I just finished installing Swift springs (sport mach) on my IX MR (stock Blisten struts) and I'm experiencing a popping noise when turning the wheel all the way to the left side. The vehicle rides good and I don't hear any noises when I go over bumps or damage asphalt. It seems that the noise it's coming only from the drivers side strut only when turning left. I took it apart twice and I made sure that the spring sat correctly on the strut. I made sure that everything was lubricated and all the bolts are torqued correctly. What else could have caused this noise. My evo only has 9300 miles and I never had any suspension issue before this. Thanks for any advices.
I checked both perches on the strut and the whole do lined up to each other. I also notice that both perches have about four wholes each, would it matter to which whole is lined up with? When I installed the spring on the strut I when based on the old mark left by the stock spring on the top perch. I hope this make sense.
projectxmatt
Jun 27, 2014 03:28 PM
speedfreak24
38
Feb 9, 2012 12:23 PM
mctenold
May 4, 2011 06:39 AM
