jic flta-2 coilovers
just wondering what settings everyone is running and how it's working out. i'm new to suspension and need some help. mine are not corner balanced, but take probably an inch or so off all 4 corners. i have the dampening at 5 clicks short of the stiffest at all four and the rear springs are replaced to be stiffer than the front (9k in the rear). my camber is -2.5 front and -1.25 rear with 0 toe. any help would be great or a link maybe to learn more about suspension and what i should be looking for cause all this info was given to me by someone who runs an evo 9 in my local scca region who had these coilovers previously.
Im running 12 on the front and 8-10 on the rear. I think the spring rates are 10 14k. There just about right for street use a tad on the stiff side but nice on the track.
I daily drive and autocross on mine. I run a minimal drop, about -2.75 degrees camber front, -1.25 rear, 1/8" toe out front, 0 toe rear, with a big rear bar.
Even re-valved, the first 5 clicks don't do much on these dampers. I run full soft front, and zero to 10 clicks firm in back.
I'm running something insane like 850lb. (over 15kg/mm) springs on mine because they came off a BSP car. The rates are much higher than what is optimal for street tires, but works for now. I'm pretty sure they have been revalved.
The car is very loose and loves to slide all four wheels, even with almost stock power. I am either going to go down to much softer springs, like 6/700lb. or change to different suspension altogether.
