anybody use these rotors?
RotorPros use Centric blanks. They are good quality. Like everyone has said, we have used these for a while, tracked/AX/DD.
And you do not want to get drilled rotors. They run the risk of cracking at the drilled points. Slotted or blank is the way to go. (Street - you may not see cracking, track days - you will. The groups I ran with back in MI would not allow cars with drilled rotors unless they where say a GT3 or the like with factory $5000 systems)
2pc rotors are more expensive and generally overkill for street use. And can be noisey.
yea, but if we want to compare apples to apples, brake planet's drilled / slotted rotors are the exact same price......the blank ones are 100 dollars less...
so rotor pro guy!....please tell me if there are any other differences you can tell between your slotted rotors and the brake planet rotors....materials....tolerances?
even if there are none, i'm buying yours because i saw you guys first and your on evolutionm....but i'm just curious...
but also.....please enlighten me.....is anybody here (rotor pros, brake planet) using aluminum centers, or no?......is that what 2 piece rotors are?
PM sent thanks!
Also, I just found out that we can definitely get the rotors blank, check out our website for updated options!
http://www.maperformance.com/rotorpr...o-viii-ix.html
I just order the RotorPro rotors and they look great. Very heavy duty.
I'm trying to change my front and rear rotors.
Can anyone help & tell me how to change-out the rotors?
couple days ago i ordered Slotted and Dimpled rotors coated with black and the brake pads Rotor pros offers.. i went directly to Rich at Rotorpros.. Great guy and very pleasant ordering experience! now i await the goods
ill post up my feedback when i receive/test em out
I installed Rotorpros on my Evo 8 track day car. I run the car very hard at the track, I'm in the Instructor Run Group and I put 5 track days on these rotors and they're beginning to crack up. Is this normal?
