KYB or Bilstein Struts
i'm definitely set on getting some swift spec r's and i'm just trying to determine which would be better performance-wise: the stock kyb's or the mr bilsteins?
i could care less how bumpy or how harsh the ride quality is since i'm still young and i'll tolerate it until i physically can't. i dd my car and i do auto-x also
i'm hearing that the mr bilstein's are softer which would mean that the stock kyb's reduce body roll correct?
again, i dont care about ride quality and i don't have much money to spend with christmas coming up, otherwise i would probably shell out for megan track coilovers or bilstein hd's. i just want to know which of the two would handle better
thanks
thanks
Stiffer dampers will only slow down body roll, not reduce it. The car will stiff fulley lean over at mid corner the same as a softer damper. It's the slower roll which makes it feel like less roll, which I suppose you could say in a very quick manuver the car would be likely to roll less. But what do I know... Nothing, really.
If you already have KYBs then stick with them. Once lowered the performance difference is minimal at best.
The Bilsteins are a bit bigger and should last longer but honestly I rarely hear about people blowing the EVO9 KYB struts by way of moderate drop.
For the record... I sold my 5k mile KYBs for $250... but shipping cost me $50.
I ended up paying close to $850 + shipping for the new Bilstein / Robispec combo.
Figure springs are $200 and shipping was $50 so out of pocket expense for the Bilsteins was $450. I don't really think the difference is worth $450.
looks like i'll buy a new set of kyb's and throw the swift on them
I just got a set of MR Bilstein's and noticed they are alot softer than the stock IX shocks, should I have just stuck with the IX shocks? I noticed when they were both off the rod end was alot softer on the Bilsteins than the KYB's. I thinking I might go back to them.
If I didn't have any suspension at all and needed something new I would say go with the Bilstein HDs or a set of low mileage MRs which are hard to find now that they are 2 years old. But if you already have a good set of KYBs just run them and call it a day until you want to move up.
