Those of you running 10" rims ...need your help/ see pics
holy wide tires......hmmmm the width of the tires doen not seem to be the problem but i may be crazy.....depending on how deep that is maybe you can grind just a little bit of that metal away to take care of your problem....is it only on the one tire?....
a lot of it is due to the height of the tire not so much the width of the wheels. Many Z guys have this issue, thats why when I had mine I went with an 18" setup with 285/30 instead of 275/40/17. The 18'' tire is considerably shorter and therefore causes much less issue in terms of rubbing
