Swift Spring... now I get a clunk
I just install some swifts on the Ix. Now, every time i make a full left turn I hear a clunk like something didn't sit correct. However the spring is sitting correctly on the top hat and perch. I am only noticing the clunk on the drivers side...
Anyone got any Ideas?? I had the GF turn the car and didn't see anything abnormal. i have yet to get the car aligned as I only finished them last night.
Ummmmm i would get it aligned and they might be able to give you an idea of what might be wrong oh yea SMIKE!!!!!!! he needs to be here, he runs swifts and would be better able than me to tell you what possibly might be making that noise, oh yea good luck to ya
the guy I got my car from put the spring on upside down. on the hat and perch right but clunked while turning and going over bumps. something is loose or the spring is not on correctly
Did you align the holes on the upper hat and lower perch? There is one hole in each on the hat and perch they are supposed to be aligned top to bottom with the shaft or the spring will not sit correctly in the hat.
Swift Spec R's painted black installed on Bilstein MR's with 100% factory hardware.
the whole didnt align on the passanger side and i dont get that clunk i removed it and just turned the top hat and finished reinstalling. i havent gone for a drive, i will be back i'm going to go get the spring compressors again from the Z.. and align the holes.
TY for the info... The Evo is so picky,,
It will not sit in the pockets properly and possibly produce the noises described.
Take your time when you tighten the shaft nuts. When you go to torque the nut it will rotate the hat so you might need to clock the hat ahead so when you reach the final torque the holes align.
i turned the top hat so that the 3 bolts shift 1 hole. The mistake i made was not marking the 3 14mm bolts on top, I guess i just got lucky on the passenger side and it went in the same it came off, however not true with the driver side thus creating the noise "clunk" issue.
and the ride quality is freaking great!!! This is how the evo should have came out of the box.
I want to thank ebay for the cheap $$ swifts, and you guys for the help. Now i need to look for some bilsteins haha
