Alignment Troubles
Alignment Troubles
I'm getting an alignment right now and they are saying there is no way they can even get it close because I have MR struts and Sprint sprints. I told them the MR struts are an OEM part so the lowering (camber) should be the only problem, right? What are the adjustments on the camber bolt? -1 +1? What specs should I have them set it at with MR struts and Sprint Spec R springs?
So I went back over there and the idiot says he can't do it because its lowered. So I just went to Avondale Mitsu and I'm getting it done there, they have no problem with doing it.
he can't do it because it's lowered, i guess none of gt300/500, f1, lemans, nascar, or any other racing team can adjust the alignment on their cars either
I myself got my Evo aligned today and I set the specs at -1.5 Front Camber, -1 Rear Camber, and 0 Toe all around. Once it got set the guy told me only the Rear Camber was a hair off (-.1). I then told him about my tirewear problem at the two front inner tires going bald. He then said to me that those specs are for racing, not for tirewear compensation which I didn't know. Now I have to go back another time and have him adjust the settings to compensate for the tirewear with no charge since the previous settings were pretty much the same. Anyone know about these settings? Btw I got the numbers from the local Evo forums. Why would people make their alignment settings for racing even though it's a tirewear angle?? Advice and comments are more than welcomed
LOL I recently went from -1.5 to minus 2.5 which is pretty aggressive for the street. The car turns in way better with less understeer but I will be wearing out the inside of the tire. To minimize this I will probably have tires dismounted and remounted so the inside becomes the outside which wil lalso require moving tires from right side to left side and vice versa to maintain proper rotating direction of tire. For some the added performance is worth it.
PS I want to get rid of this set of tires as I really do not like them
CaptainSquirts
Aug 31, 2016 03:15 PM
mantazini
Apr 11, 2016 01:49 PM
<--MOVE OVER
66
Oct 7, 2011 01:10 PM
yank1969
Jun 23, 2005 02:42 PM
