best size tire for 9.5" wide +27 offset wheel
no, it'd be 26" and 81.7" respectively. To calculate, you take
Tire Height = (width / 25.4) * aspect Ratio / 100
Tire Diameter = (2 * tire height) + rim diameter
Tire Circumference = tire diameter * PI
You are going to have to work the crap out of the rear fenders with those wheels. 255's will fit with the standard cut or roll of the fender. Anything wider will require pulling as well. Especially if you are going to track the car.
People have fit that wheel, but it takes lots of work out back.
For the OP, +27 is way too low an offset for that wide of a wheel. You should really be running a +32 or +35 offset.
FS[Northeast]: Enkei NT03 18x9.5 +27 with Dunlop Z1 Star Spec
psushoe
For Sale - Wheels / Tires
Aug 15, 2016 03:54 PM
