NT03+M 18x9.5, differences between +27 & +40 offset?
![Question](https://www.evolutionm.net/forums/images/icons/icon5.gif)
Ok, I know when fitted the +27 wheel is 13mm further outboard that the +40 ![lol](https://www.evolutionm.net/forums/images/smilies/lol.gif)
But seriously, does anyone who runs the +27 on the front and +40 on the back, or any of the traders that sell these wheels, know exactly where the differences in the offset are designed into the wheel.
ie, are the spokes a different angle, or the outer rim a different width or is the inner mounting face thicker on the +27?
Reason for me asking is I have a set of +27, and I am fitting them to an Evo 6. On the rear I need to move the wheel inboard by around 10mm, and if the difference in offset is in the thickness of the hub/mounting face of the wheel, and everything else on the wheel is identical, it means I can just machine 10mm off the inner face.
Thanks in advance for anyone who can inform me of the facts
![Thumbs Up](https://www.evolutionm.net/forums/images/smilies/smilie_thumbsup.gif)
i dont believe the spokes would be any different, they would have to concave out. IMO it would look bad.
correct me if im wrong someone, but i believe the purpose of offsets is to widen the track of the car to allow a wider tire, if the wheel dosnt stick out enough, then a wide rim will go IN farther, meaning its likely to hit your wheel well. our cars, i extreamly doubt a +40 in that size would even fit without a 500MM spacer.
i have nto3s in 18x9.5 +27 and love them, they look amazing, however you need 10 mm spacers up front for the +27....
Thanks in advance for anyone who can inform me of the facts![Thumbs Up](https://www.evolutionm.net/forums/images/smilies/smilie_thumbsup.gif)
While it seems logical that you could machine material off the thicker 27et back, you can't. The material thickness under the lug counter bores are the same on both wheel offsets, so it would weaken the lug area. Better to use 40 et rear with a thin spacer, and 27et front with no spacer.
![Crap](https://www.evolutionm.net/forums/images/smilies/crap.gif)
Oh well, I'll just have to modify the rear arches instead, thanks for your help
![Smilie](https://www.evolutionm.net/forums/images/smilies/smile.gif)
I would have got +27 front, +40 rear, but the wheels I got were the limited run matt black ones that Touge Factory sold, and they only came in +27.
evil03
1180
Sep 21, 2021 10:31 PM
tiltmode43
For Sale - Wheels / Tires
10
Dec 7, 2011 08:07 PM
Lightsped
Feb 24, 2011 01:52 PM
andrewdruiz
Aug 2, 2008 01:42 PM
