Popping from front left corner
I suggest you check the ball joints as they tend to pop when they go bad.
Do you notice that your wheel feels like it pulls to the side a bit even though you got a alignment? Sometimes when the joints go bad even if you get an alignment you still can feel the wheel going off to one side.
https://www.evolutionm.net/forums/ev...end-noise.html
You can find many people having this issue and this is a great thread.
Good luck
Good luck
![Thumbs Up](https://www.evolutionm.net/forums/images/smilies/smilie_thumbsup.gif)
i checked all data a couple times no mention of anyting with popping or strange noises from the wheels...auto instructor said it could be a cv joint but he would have to ride in the car to hear it
I'm not having a clunking noise. It doesn't happen when I hit bumps. It sounds like metal binding only when turning. It is very noticeable when the car isn't even moving.
good luck to you, let me know what you find.
well after putting the car up I could not get it to make the noise again. So I jacked up the suspension to put a load on the spring, still nothing. All of the suspension parts seemed to be moving smoothly. I would think if it was a cv joint it would always make the noise. I'm at a loss now. Any other ideas?
well after a short drive I quickly determined that it is a bad strut. Now it makes a horrible clunking noise hitting bumps at slow speeds. I can't believe that a megan strut would go bad this quickly. Guess I'll be taking it off and sending it to megan this week.
Mine is doing the EXACT same thing how strange! I Have Tein coilovers and just put on some cusco camber plates. Sometimes when I turn right/left the springs will pop and make a loud "ping" noise
. Then the top strut bolt will loosen up....CAN SOMEONE PLEASE diagianois this?
![Confused](https://www.evolutionm.net/forums/images/smilies/confused.gif)
This is an easy one! If you turn your wheel and a loud bing occurs your spring is binding up on the perch then releasing. I had it happen to previous cars with suspension. One way fix this is a little lithium grease and you can try putting a rubber house enderneath and above the upper and lower perch. Another words have the spring sit on the hose rather than the perch, This should work!
I had the same thing happen right after I installed my megan track coilovers awhile back. I took out the dampener adjustments for the fronts (they slide out). Then I got a metric allen wrench, held the shock and tightened the nut. It has to be really tight, after that I sat at idle turned each way and no more creaking noises.
gbwaacha
Sep 12, 2003 02:24 PM
