MAX Rim size ??
MAX Rim size ??
hey guys
i own a 2003 evo 8
i was wondering im looking to start searching for rims, i was wondering whats the max rim size i can go on my car with out needing spacers or longer studs.
also whats a right fitment. 5x100? 5x114? i was thinking of either 17x9's or 18x 9.5'
just that i dont know alot about rims iv always kept to stock wheels i have searched and didnt find much
i would appreciate ur help guys thanks
i was looking to get rota torques posibly the 17x9; 5x110 or 114 or 18x9.5's just seeing which woudl fit best
i own a 2003 evo 8
correct me if im wrong but if you go to a 9.5 width wheel you will need spacers in the front right? 15's i thought. a 17X9 or 18X9 would work perfect depending on whether your going to track the car or not. i would go with something a lil better and stronger than rotas but hey, i know how the money thing goes (im in the same boat) and the rotas look good. gl my man
Honestly, I would get a good quality rim in a 17x9 or 18x9 with an offset between +29 and +38. You only get what you pay for and I have seen Rota Wheels literally grenade on a track. I used to run a 17x9 Advan with 255/40 Z1's and loved em. Fitment was perfect. But I had the money and decided to go a little more aggressive with an 18x9 +29 and a 255/35 Z1 which still fits great. BTW, your bolt pattern is 5x114.3 and I don't think you need spacers with a 9.5 inch rim with the proper offset. Why do you want a 9.5 inch rim anyway? Do you plan to track?
running a spacer doesnt have to do with the rim width, its dependent on the offset and shape of the spokes. You can run the Advans in a +29 offset with no spacers but an RPF1 or NT03 in +38 will require 10mm or more to clear the calipers.
18/9.5 35mm 5 Zigen.........NO SPACERS NEEDED CLEARS BREMBOS FINE
275/35's all day long......285/30's w/ 4-5mm spacers (keep inner tire off the strut)
285/30 test fit....1mm between tire and strut....yes that is a business card in there..
This aint a lowrider stretch illusion from your latest show and shine thread....this is real meat to throw down real grip...I wish I had a pic of the 285 mounted on the back...it looks hella insane wide....with a 200 treadwear it would be a guaranteed killer lane changer/slot car.
If your not too low you could get away with this 285/30 combo and NOT RUB
v8<turbo4
12
Mar 2, 2023 12:43 PM
ant_turbo
Dec 5, 2016 10:39 AM
EClark11GTS
Feb 6, 2016 02:26 PM
DrivelineSales
Evo 'For Sale' Wheels / Tires
18
Nov 22, 2014 07:11 PM
WheelDude.com
13
Apr 14, 2014 03:28 AM
