Wider track or wider tires ?
I completely agree, why use a spacer when you could fit a 335 tire in the well.... If HKS thought a 335 tire would be faster than a 1" spacer I would think they would do it. But, as Nils said, maybe the mentality is that strong...I would like to see what they'd do with the fattest tire they could fit.
Porsche has been using spacers wider than that for years.
Narrow tires heat up faster than wide ones, all other factors being the same. (or should I say that smaller contact patch means more load, more heat) 3 laps isn't enough time to get enough heat into some compounds. Something to think about.
I think that if wider tires made the cyber evo faster that they would have them. There is no other evo track car in amateur racing that has had more money dumped on it for development.
My references
http://wtac.org/
http://www.youtube.com/watch?v=kqjKxDFEK98
My references
http://wtac.org/
Bimmu, I'm with you in thinking that if a bigger tire was going to make either of the two car's I'm talking about faster they'd use them. I just don't think HKS would go to the effort to make such an outrageous car and then stick with 265 tires because it fit with the status quo in Japan.
For track guys...
If you had to choose and cost was not to be the deciding factor:
Suspension geometry/track or supa fat meats 295+ and could only have one for an evo, which would you take...
For track guys...
I'd take the suspension geometry before taking the wider tire. I also can see the unsprung weight argument. From experience though, I'm faster on a 295/30 than on a 275/35 through an autocross course, with both tires on 8" rims. In autocross, more rubber on the ground is generally better. Less unsprung weight, and especially less rotational inertia in the wheel, can make a big difference on a track though.
Nils, I had a feeling you'd say that
GTLocke13, a 295 on an 8" rim...Wowza !!!
My references
http://wtac.org/
My references
http://wtac.org/
Team Tarzan Tomei/Cusco/Voltex Impreza won Super Lap Battle on 275s.
When i talked to the suspension engineer at PRI Show in december, he said that they couldn't get enough heat into wider tires for those few laps, he also mentioned the weight issue.
There is an article in Race Car Engineering, I think one from this year that discusses the difference and tradeoff. We've covered it here pretty well. More weight with larger tires but better cornering. Better top speed with narrower tires but less corner speed so you will theoretically enter the straight with less speed... tradeoff. Combine that with the short amount of time to get heat into the tires when making a decision.
Another note is that factory teams have access to compounds that are "improperly" labeled.
