Help on install for cusco e-con dampining controller
i just bought the e-con dor my zero-2e coilovers. The directions came in japanise and i have been looking for a wile to try and find directions in english. if anyone could possibly give me the web site that i can find directions in english. Or if anyone has installed the e-con personally, then that they can exsplain to me how to put on the system.
thanks for the help
thanks for the help
What problems are you having with the E-Con install? To connect the E-Con electronically, you'll have a red wire (Power), black wire (Ground), and a orange or yellow wire (Light Dimmer). Install the the E-Con on top of the Zero2E coilovers then connect your wires. Your E-Con should work.
When the E-Con turns on, it'll make a clicking noise...this is normal because it's doing it normal start up mode.
MrJoshH
May 25, 2015 11:21 AM
Sam@DriveLine
Evo 'For Sale' Suspension / Brakes / Handling
43
Jan 8, 2009 02:19 PM
Vivid Racing
Feb 29, 2008 04:21 PM
con, controller, cusco, e, econ, econn, english, guide, install, installation, instruction, instructions, wire, wiring
