Tire Valve Hole Size OEM BBS ???
mitsuatb, I'd help you out as my BBS are unmounted at the moment, but the OEM valve stems are still installed on the rims. What are the two sizes you are looking at for the metal stems?
The OEM stem on the SE BBS measures 15mm (.591") at the exterior of the rim and 17mm (.669") at the base of the plug on in the interior of the rim. It is marked with the code TR413 which I believe corresponds to a .453" size.
Igaly1021
Jul 8, 2015 05:43 AM
Johnr352
Dec 13, 2010 04:56 PM
