5Zigen FN01R-C 17z9 +15???
I'll help with what I can. For the rears you will need to roll the fenders and more than likely reposition two of the rear bumper support bolts. I HAD to do this to get my +22 offset gramlights to fit, so I can only imagine the same will be needed for your +15. As for the fronts, I'm not sure of the backspacing on your particular wheel, so I'm not sure if spacers will be needed, but you may need to run a little more camber.
![](https://staticssl.ibsrv.net/autocomm/EvoM/fcotmicon.gif)
They should fit without spacers and are as agressive as the +20 grids on the outside. You get 10mm more clearance than stock, but who knows about the backspacing and sheet. Gotta imagine if people are running them in higher offsets without spacers, they have to fit in lower offset without spacers as well.
Revobasher
Sep 27, 2015 04:41 PM
4g63girl
Nov 16, 2014 05:19 PM
4g63girl
Sep 23, 2014 10:13 PM
