sway bar question
Old Apr 1, 2009 | 03:43 PM
Cynic's Avatar
sway bar question
quick question for anyone who can answer.looking for sway bars for my evo.right now im checking out the cusco sway's.from looking ive found 21 and 25mm front bars and 18 and 23 mm rear bars.apparently from looking online the stock sway bars 23 mm.but in looking at upgraded sway bars alot of websites are stating that the 25mm front and 23 rears wouldnt be good if used for everyday driving.can anyone comfirm or deny this?
ive tried looking for older threads on this topic and couldnt find any.if youve seen one a link would be appreciated.if not.feedback would too. grass muchos
Old Apr 1, 2009 | 04:22 PM
Smike's Avatar
https://www.evolutionm.net/forums/ev...-reviewed.html
I run the Swift front and rear set.
I don't think many are running the full set. It was not that bad of an install. At my shop it took only a few hours.
Old Apr 2, 2009 | 01:26 AM
Cynic's Avatar
how big is your set of bars???mm size?
Old Apr 2, 2009 | 05:11 AM
Smike's Avatar
Swifts are actually thinner(lighter), but its a stronger/stiffer material. So they are not judged by mm. They are 18% stiffer up front and 20% stiffer in the rear.
Old Apr 2, 2009 | 06:52 AM
EVO8speed's Avatar
check out robispec sway bars. I just ordered some yesterday
Here is the HKS Kansai sway bar specs:
Front 2 Way Adjustable 25mm Sway Bar
Soft Setting: 120% Increase Stiffness
Hard Setting: 135% Increase Stiffness
Rear 3 Way Adjustable 24mm Sway Bar
Soft Setting: 135% Increase Stiffness
Medium Setting: 163% Increase Stiffness
Hard Setting: 200% Increase Stiffness
Old Apr 2, 2009 | 08:19 AM
boomn29's Avatar
Keep in mind, a swaybar is only used when cornering. When driving in a straight line they are not even used. This is why it's a big item for tracked evos; to take care of the turns better.
I have run a larger RSB; a 25mm adjustable Hotchkis both on the track and on the street. I liked the feeling of it on the street personally. If you do go big/thick and stiff, be careful gunning out of tight turns when it's wet as it may induce extra oversteer!
Old Apr 8, 2009 | 12:42 AM
Cynic's Avatar
cool thanks for the help gents
Old Apr 9, 2009 | 12:02 AM
Go_Lancer_Go's Avatar
what is a good pair of bars to get that will it make it so the sway is kinda gone but prevent extra oversteer (aka *** end kicking out)
Old Apr 9, 2009 | 12:16 AM
Sr20kidD's Avatar
cynic = frank??
im running the progress 27mm on hardest setting. I love the oversteer.. only use it if you know you can control it...
Old Apr 9, 2009 | 03:48 AM
krisdlm's Avatar
^ does progress only carry 27mm sway bars, i've only seen 25mm at most. Is longer necessarily better?
Old Apr 9, 2009 | 08:45 AM
GTWORX.com's Avatar
It's thickness, not length. And no, thicker isn't always better. Too thick in the rear (ewww) and you can start lifting inside rear wheels.
It's nice to balance a bigger rear bar with a bigger front bar. The front bar just sucks to install but it's worth it!
- Andrew
Old Apr 9, 2009 | 02:21 PM
krisdlm's Avatar
^ thanks for the clarification
Old Apr 9, 2009 | 05:12 PM
andres_d85's Avatar
I currently run the Agency Power 27mm Adjustable rear swaybar and its amazing... (I like the oversteering)
Old Apr 12, 2009 | 01:43 AM
Cynic's Avatar
nope cynic does not equal frank.cynic equals me...
Old Apr 13, 2009 | 10:49 PM
Fast-Mover's Avatar
im about to install mine, is the oversteer reallyu bad? or is it managable
Quick Reply: sway bar question
