need brakes & tires
Old Apr 10, 2009 | 10:35 AM
barneyb's Avatar
Originally Posted by SmikeEvo
Not quite true, there are better pads.
And its all about it.
But there are pads that have more bite for less than the OE's.
I didn't mean to imply that you couldn't get more bite but some installers can make these more aggressive pads keep quiet and some can't. My opinion is that the maker hit the sweet spot in the bite versus noise trade off. Maybe that sweet spot isn't where you want to be but the maker did a good job. Too bad they are so expensive.
Old Apr 10, 2009 | 12:30 PM
andres_d85's Avatar
look into Bridgstone RE01Rs for $95 closeout in tirerack... i just got those... check'em out...
Old Apr 10, 2009 | 12:43 PM
Hikaru's Avatar
^^Awesome deal!
Old Apr 10, 2009 | 01:33 PM
andres_d85's Avatar
Yeah it is! and the shipping is great!!! ordered them on wed. afternoon and got them today at 11am- just for auto x on sunday... perfect timing
Old Apr 10, 2009 | 04:14 PM
bbyevo8u's Avatar
Originally Posted by Hikaru
Check out Ferodo DS 2500 brake pads. Very common and popular with this crowd. For tires check out the Dunlop Z1 Star Spec. IMO one of best replacements for stock tires out especially considering the price.
hey thanks i think i'm going to go with the "Ferodo DS 2500" but the place i'm going to by them from says its for 03-05 evo i have an 06 they should be the same right?
Old Apr 10, 2009 | 04:20 PM
typac69's Avatar
Id just get hawk hps pads.. i think all the way around is under 180 bucks..
Old Apr 10, 2009 | 06:20 PM
bbyevo8u's Avatar
i have herd of the hawp pads wraping rotors!! is it true?
Old Apr 10, 2009 | 06:22 PM
bbyevo8u's Avatar
i want something just as good as oem or better
Old Apr 10, 2009 | 06:24 PM
Smike's Avatar
Warping is misleading. Pad transfer is a correct way to think of it.
My HPS's - glazed over and useless. I do not recommend them.
http://i85.photobucket.com/albums/k6...o/DSCF0649.jpg
http://i85.photobucket.com/albums/k6...o/DSCF0650.jpg
OP - again, GranSport GS5s, GS6s, PF Z's, DS2500s, etc.
Old Apr 10, 2009 | 06:41 PM
bbyevo8u's Avatar
ok thanks again smikeEvo i have one more question, i have never changed out the brakes on an evo before but i have change the brakes on my old sti, i unbolted the two bolts that were holding the caliber on then i just slide it right off the rotor is this the right way to do it (should i do it this way on the evo)?
thanks everyone
Old Apr 10, 2009 | 06:43 PM
Hikaru's Avatar
Same brakes man.
Old Apr 10, 2009 | 10:07 PM
bbyevo8u's Avatar
^^ thanks.. can someone give me advice with changing out the brakes, should i change the brakes by unbolting the caliber and sliding it off the rotor?? i have searched for step by step info but cant seem to find anything good, also the brakes come with a jelly type of paste what do you do with that rub it on the brake so it dont sqeak?? sry i'm a newb with brake jobs
Old Apr 10, 2009 | 10:25 PM
Evoardo IX's Avatar
No you don't have to unbolt anything (well, just the tire obviously ) the caliper has 2 pins, push those with something, then pull the old pads out, put the new ones in (might have to push the pistons in because new pads are thicker) then put the pins again and that's it. The grease goes on the sides of the pads (not the ones against the discs) and on top where they sit against the caliper. There is a couple threads about pad change, that's how I learned to do mine, I hope this helps, make sure you search and do it right because brakes are an important safety feature of your car good luck.
Old Apr 11, 2009 | 04:42 AM
Smike's Avatar
This.
Old Apr 11, 2009 | 10:18 AM
barneyb's Avatar
I suggest reusing the metal shims that come on the OEM pads. I always have and I haven't encountered the problems with brake noise written about so much here (the pad you choose will make a big difference with noise too - some racing pads are near impossible to make quiet) . For lubrication I apply a little dab of stiff grease to the lips of the pistons - nothing else.
Quick Reply: need brakes & tires
