will 18x7.5 +45 offset, adr sokudo wheels fit on evo 8?
like title says, will 18x7.5" adr sokudos with a +45 offset clear the brakes? if not, can a spacer be used to solve the problem?
Depends on spoke design which will tell how much spacer you will need. At minimum, you would need about a 10mm spacer. Then you would probably need longer studs. Find a wheel that has a proven fitment.
