Toyo proxies air pressure?
what are you guys running in your 235 45 17 toyo proxies ra1 for air pressures front and back? Hot and Cold?
This weekend will be the first time on them and I want to get them in the ball park off the bat.
Thanks!
Thanks!
You want to shoot for 40psi hot. As in 40psi when you come off the track. The ambient temp will determine what you set them to cold, but something in the range fo 35 is a good start this time of year. In the middle of summer, I'll start r-comps down around 33.
Fwiw; the RF at Gateway gets really hot from the oval and the LR doesn't do much at all.
