Q: How much does toe change with camber change?
Just a curiosity question that some with camber plates may know the answer to. Say you set the toe to 0 at -1 camber. Then you up the camber to -2 or -3. By how much does the toe change as a result of the camber change?
I know it will be different on different cars, hence the EVO specific question.
Thanks.
Thanks.
For reference on too much toe - a buddy of mine chunked off a brand new RA1 in 1 day. He had no idea why just 1 tire wore through; then he checked his toe using the string method and seen he had about 1/4". That's all it took to ruin $235!
It's not so much the amount as the direction. Adding negative camber adds toe IN. This will make the car turn in horribly.
The last I checked -2->-3 degrees of camber will take you from zero to 3/8" in.
d
EDIT: this is of course the opposite of the subarus which toe out.
d
I have a question to add to this thread seeings how there seems to be some people with experience in this area responding:
Has anyone ever measured how much toe change you get per rotation of the tie rod?
My interest in this stems from my want to change toe while at the track or autocross with minimal tools and time. I normally align with zero toe all around for the street and put marks on the tie rod where "zero" is. So at the track if I determine I'd like some toe out, I can shorten the left and right tie rods by an equal amount (usually measured in 1/6th's of turns since the tie rod has six sides on the adjuster and it's easy to eyeball) to play with to changes. Then at the end of the day turn them both back to my zero toe setting and drive off.
Thoughts?
Thoughts?
I know I have the numbers at home, but I believe it's about 3.3/16" toe change for one turn of the tie rod. It's a lot easier to just adjust one side and have the steering wheel be a little crooked during the event.
Then by all means go ahead. It's just one more thing to remember to do (and then un-do at the end of the day).
At one time or another I've forgotten to do just about everything possible when going from a street to autocross setup and back. Simpler is better for me. The crooked wheel is a nice reminder I've forgotten to change the toe before the drive home (or adjusted it the wrong way!).
Hey, a lot of folks have gievn you good advice. I'll kind of sum it up...if it were easy and little adjustments didn't make that much difference we would all do alignments in our garages. If you mess with it( alignments) you will continue to do so and finally--in the end it will be back at the shop. In my experience even setting the adjustments "back" where you had them originally --doesnt work..something is always out, car pulls, steering wheel is crooked, and sometimes it the little things---I hate a crooked wheel or a car that pulls even a little bit... If you dont believe it...try it and reread this in a week.
Get a set of toe plates so you can check it occasionally. Over time it will usually go out of alignment, so you'll have to reset it.
or just get an aggressive alignment done, tell them what you want and theyll do it for you. camber change effects toe, not vice versa, but you cant change your camber and not fix your toe
J!n K@z@mA
19
Mar 8, 2016 11:34 AM
