Which way should slotted rotors face?
I know rotors should be installed per the manufactures instructions. And that the only important thing is to make sure the inner vanes are facing the correct way. But on straight vaned rotors does it really make a difference which way the slots face? I.e. whether they cut from top to bottom or bottom to top? Isn't gas removal the same? Discuss...
I've noticed that different manufactures use different slotting patterns. Some do one way and some do the other. I guess it's just preference. My friend's Girodisc rotors run the slots one way and my DBA 4000's run them the other way. Both were installed per the instructions. I was just wondering if companies believe running the slots in a particular direction improves gas removal.
Well as far as i have heard on track from specialists if the manufacturer did'nt mark them left/right, 5 or less slots the outer edge of the curve should point to the rear of the car, more then 5 slots they should point to the front of the car. Dont know why, but that's just what i've been told and seen on most racecars that have 5+ slotted discs they almost always face forwards. perhaps someone can shed more light on the correctnes and why of this.
Slotting and drill patterns can face either direction depending on the vane design of the rotor. Pillar vane (or kangaroo paw per DBA) and straight vane can go any direction. Curved vane rotors need to have the vanes spiraling out and back from the direction of rotation regardless of what is on the face.
Martin
Martin
Martin
Martin
I believe he is saying that the top of the inner vanes should be facing towrds the rear of the car if they are directional. the outer design doesnt matter and if they arent labeled your gonna have slots on one side facing opposite just becuase all four rotors were designed with the same dirrection. but unless its a directional vane rotor it shouldnt matter.
If you look at the top vein it should curve the direction a c would curve (towards the rear). That's how I understand they go, that is suposed to help with venting or removing brake dust (I forget)
JRitt@essex
Apr 29, 2016 07:30 PM
EVOlutionary
90
Feb 8, 2016 09:45 PM
cquencebrakes
Vendor Classifieds
20
Dec 28, 2015 06:47 PM
Swiss
Jun 10, 2014 12:39 PM
