Torque specs for control arm bolts after RCA kit install
I do not have a factory manual and installing the whiteline RAC kit. The whiteline instructions do not provide any bolt torque numbers.
I found this nice writeup:
https://www.evolutionm.net/forums/ev...ml#post7116123
...but, it has no torque specs for all the bolts either. Can anyone fill in the gap by supplying the factory torque specs for:
1) Control Arm bottom bolt
2) Control Arm side bolt
3) Sway bar end link bolt
4) Ball joint bolt
5) Tie rod bolt
And please refrain from just saying: "just get as tight as you can" ...that is useless
Thanks
4) Ball joint bolt
5) Tie rod bolt
Thanks
Probably more than u need but hey more is better right.
Front axle crossmember bar bolt
49 ± 10 N⋅m (37 ± 7 ft-lb)
Lower arm to crossmember connection bolt (Rear)
167 ± 9 N⋅m (123 ± 7 ft-lb)
Lower arm to crossmember connection bolt (Front)
186 ± 10 N⋅m (138 ± 7 ft-lb)
Lower arm to knuckle connection nut
108 ± 10 N⋅m (80 ± 7 ft-lb)
Stabilizer bar bracket bolt
39 ± 5 N⋅m (29 ± 3 ft-lb)
Crossmember to body connection bolt and nut
Crossmember bolt
Rear roll stopper connection nut
52 ± 7 N⋅m (39 ± 5 ft-lb)
Stabilizer link bolt
Stabilizer bracket bolt
21 ± 4 N⋅m (16 ± 2 ft-lb)
Steering gear and joint connecting bolt
18 ± 2 N⋅m (13 ± 2 ft-lb)
Steering shaft cover bolt
5.0 ± 1.0 N⋅m (44 ± 9 in-lb)
Tie rod end to knuckle connection nut
25 ± 5 N⋅m (19 ± 3 ft-lb)
Crossmember bolt
EGbeater
Aug 6, 2021 05:47 AM
FS[Northeast]: Complete New Whiteline Suspension Setup
OverBoostedEvo
Apr 9, 2015 01:14 PM
xXANCHORMONXx
Dec 13, 2012 04:33 AM
