14kg front /16 kg rear coilover
I am considering buy a set of coilover with 14kg /16kg spring rate F/R(buddy club rate spec with swift springs) but was wondering how STIFF that's gonna be? I know those are track spec, I am kinda guy who would fall asleep if driving a stock ca on the freeway. But I would still like to know how stiff 14kg and 16kg is? Will the car slam and make a very loud noise when I go over the bump etc? I daily my evo.
Thx
Thx
I run 16kgF/12KgR on Tein HT's. Not that stiff at highway speeds. Have double adjustable shocks, set at 8/8 F and 12/8R, Comp/Rebound. I like them. Not bad for daily driver. NOw, I just need swaybars...
Well the freeway around my area is a little bumpy due the way how there are many Fault lines are in southern cali. Even when I am running stock suspension now, it's a lil bumpy so not sure how it's gonna be like with the 14kg/16kg.
It def won't be comfortable. That said i run fairly stiff in my car and my kids (both of them) passed out in the back today.
It really comes down to what you are willing to tolerate. Personally I love competition and am willing to deal, if it was just a DD type thing I would def run softer.
Actually I go to track once a while and go to canyon maybe 6-8 times a month. But the thing is there are also rocks and gravels + bumps on those canyon roads. So maybe 10kg /12kg?
and sometimes I drive my gf around , so she is probably gonna hate it.
You also have to consider the dampers play a role in ride quality as well. On my car with Ohlins DFVs and 9k F / 11k R, the car rides slightly better than stock on the street. With good dampers (Koni, Ohlins, KW, AST) you could run 10k / 12k and it would probably be not much worse than stock, hypothetically. I don't know anything about the Buddy Club dampers, unfortunately, so I can't tell you if they would be "streetable" with stiffer rates.
That said, unless you're doing competitive autocross/time trial/road racing, there's no point at all to run uber-stiff rates. If you're just doing casual track days every once in a while, then err on the softer side. It doesn't make a lot of sense (to me, anyway) to have a car that's 90% street and 10% track, but have the suspension be 90% track and 10% street - especially if you aren't also considering changes to tires, brakes, or alignment. A stiffer setup will also be less forgiving at the limit and harder to learn on.
IMO 10/12 is a great streetable and fun setup. Probably well balanced on the track and not too tail happy. For autox it will be a tad pushy, but easy to drive. If you intend to run anything other than street tires they will be a bit soft.
I am currently running 255/35/18. I would say amateur level. I have no problem keeping up with my friend's SCCA prepared honda cup s2k(when I was running R compound tires) , and he was like 3rd place overall. But I am more like the driver type and not much experience on the mechanical side. The canyon road aren't too bad, just once a while after rain there will be rocks and the bumps aren't big jumps like the WRC.
I ran it full soft when not on the track. I didn't DD the car, but I did drive it to/from the track. On interstates and good roads it's really negligible. If there was a raised overpass my butt would actually come off of the seat. If you still have the stock seat, it's not bad. Switching to a racing seat would make a larger more 'uncomfortable' long drive experience.
If i remember right evolutionary was running 13/15 but that was on a perfectly valved set of ohlins...I myself wouldn't mind 12/14 on some jrz's or ohlins, but i just can't afford those yet.
