Seperated caliper am I screwed?
Old Jun 26, 2009 | 04:11 PM
AngryEvo8's Avatar
So I took one of my front calipers apart while doing a wheelbearing install. I was wondering when I reinstall it, is it going to leak? The bolts removed where the ones on the back that splits the caliper in two. Thanks
Old Jun 27, 2009 | 02:32 PM
AngryEvo8's Avatar
Bump
Old Jun 27, 2009 | 05:56 PM
emagdnim8's Avatar
So, instead of removing the caliper from the hub, you took it apart?
Old Jun 27, 2009 | 08:54 PM
AngryEvo8's Avatar
I took the front caliper apart instead of taking out the pads to get it off the rotor. With the four bolts on the 4 bolts on the backside of the brembo. I know the correct way to go about removing the caliper now. I'm just wondering if this will cause it to leak when I connect the brakeline back and the caliper.
