Wheel wont come off
Old Jul 2, 2009, 09:50 AM
YNGEVO's Avatar
Wheel wont come off
So i jacked up the car and took off all the lugnuts and the tire is like stuck on there. I had just drove it like 30miles so maybe its the heat that caused it to get stuck. Or is it something else.
Old Jul 2, 2009, 09:52 AM
TeStUdO's Avatar
Man up and get it off.
whitegalant's Avatar
kick it
Old Jul 2, 2009, 09:58 AM
Ronnie Size's Avatar
either kick the tire (not rim) on the top or bottom hard or use a sledge hammer on the backside of the tire from underneath (note if you cant aim -- dont do this)
Old Jul 2, 2009, 10:00 AM
kwanza's Avatar
Use a breaker bar, and get a pipe to slip onto the handle to increase the length of the handle. This will provide more leverage, but becareful so the pipe does not slip as you apply pressure.
Old Jul 2, 2009, 10:01 AM
JDMevoBOOST's Avatar
This thread is full of win. I vote head butt the rim.
Old Jul 2, 2009, 10:02 AM
Originally Posted by jdmevoboost
i vote head butt the rim.
lol!
LancerEVA06's Avatar
You'll break cords...
Grab a dead blow and start whacking the back of the wheel itself (lip). I just had to go through this and for about 5 minutes I was swinging that dead blow as hard as I possibly could.
Old Jul 2, 2009, 10:03 AM
Kilratio's Avatar
Originally Posted by whitegalant
kick it
+1 , sit on your butt and kick the tire on the base. It's just stuck, very common.
Old Jul 2, 2009, 10:12 AM
BlueDemon's Avatar
This.
Old Jul 2, 2009, 10:19 AM
Smike's Avatar
Location: somewhere testing various tires, brakes, and suspensions.
what is this OT?
Muscle up.
Old Jul 2, 2009, 10:22 AM
andrewzaragoza's Avatar
to remove this loosen up your lug nuts but do not fully remove. then put down the car. jack it up again and remove it.
Old Jul 4, 2009, 02:03 PM
barneyb's Avatar
This was a constant problem on DSMs, the wheels would rust weld to the rotors. The rotors would rust weld to the hubs too but that is another story.
Anyway, the way you removed a rust welded wheel was by jacking the stuck wheel until the tire was just off the ground. Then with a 2x4 longer than the width of the car, slide the board in from the opposite side and hit the tire at the bottom. One hit will do. Have a throw rug on the pavement to keep from marking the wheel.
Old Jul 4, 2009, 10:42 PM
The rotors on my ES rusted onto the hubs. Broke six (6x) Class 12.9 bolts trying to remove them. But good idea with the 2x4, I may have to try that next time the wheels get stuck on my cars.
EDIT: 4 bolts were 12.9 and 2 bolts were A-2 Stainless.
Old Jul 4, 2009, 10:54 PM
Evo209Viii's Avatar
hahahahaha
Quick Reply: Wheel wont come off
