Will wheels with 38mm offset fit the evo?
i need to know if 18x8.5 inch wheels with a 38mm offset and a 5x114.3 bolt pattern will fit my evo. Anyone know?
It still all depends on how the wheel is built with it's spokes. The biggest problem is not only being able to clear the brembos with height, which most 18" wheels can clear, but if the front spokes will not rub up against them. Take a look at your stock wheels and see that there is not much room between the spokes on the wheel and the front brembos. With the EVO it all depends on clearing the front brakes not matter what the size. Then you can worry about clearing the other stuff that causes rubbing.
Atomic646
11
Jun 4, 2015 10:23 AM
EmirEvoEight
12
Sep 9, 2014 04:01 AM
08_tweek
Jan 18, 2008 05:30 PM
RSRRSR
Nov 10, 2006 04:03 PM
