Will I be ok if i run a set of 265/35/18 up front and set of 285/35/18 out back?
Or like you said, just go big all the way around.
The reason i dont want to put any wide fenders on the car, is because i will no longer be able to use plastic fender liners. And little rocks and stuff will make a bunch of nouse hit under the wheel wells.
similar, for example if the tires are more stretched out more in the front of a evo it would be a slightly different diameter than than the back less stetched tires, but you could even it out by tire pressure to a certain extent.
