18x8 +36 with a 25mm spacer: Fit a stock bodied evo?
I know this sounds like a f***ked up size here. but can anyone tell me:
Will an 18x8 +36 with a 25mm spacer fit a stock bodied evo fit?
With 245/40 tires
Thanks!
So here's the next questions. Which tire setup has a better chance of fitting:
245-35-18
OR
235-40-18
With 245/40 tires
Thanks!
245-35-18
OR
235-40-18
I think it'll fit. You'll probably need to roll atleast the rear fenders, but I'm sure it'll fit the stock body.
And yes. You're right. The wheel would be equal to a 18x8 +11.
http://www.1010tires.com/WheelOffsetCalculator.asp
I don't think they will fit. I think your better off with a 10mm spacer. That would be 18x8 +26. 245's will fit a 8" rim but less sidewall flex with a 235. So 245/40-18 or 235/40/18.
I think your better off with 18x9.5 +30 with a 265/35-18! This is my number one choice of wheel and tire size for the Evo! You could also run a 255/40 or /35 on a 9.5" rim but the 265 would be hands down the best size.
Problem is, i cannot run a spacer smaller than 20mm b/c the caliper will interfere with the rim. And these rims don't come in any better size.
I don't mind the extra side wall with a 245/40 b/c i'm at the drag strip more often than the autox.
I'm going to have to buy a tire and then see if it looks like it will work if the fenders are rolled
Any other feed back??
evil03
1180
Sep 21, 2021 10:31 PM
smgevo
108
Mar 13, 2018 08:45 PM
WheelDude.com
Evo 'For Sale' Wheels / Tires
49
Oct 16, 2012 11:30 AM
