Advan Sport installed
Old Aug 16, 2009 | 09:50 PM
k270kmh's Avatar
Angry Advan Sport installed
Hi guys,
I installed 4 brand new advan sport tires in my Evo 7.
My initial impressions vs A046 are:
1- Steering feel: Light, precise.
2- Comfort: Small irregulatires 25% more comf, big irregularities almost equal to
A046
3- Stability at low speed: good
4- Stability at high speed: HORRIBLE
5- Slalom: HORRIBLE / NIGHTMARE / Do you want to kill yourself? Buy this tire!!!
The rear end become instable, I feel the rear tires flexing... A very BAD feel!!! like gelatin!!!
I know that the A046 are the best tires for the Evo, but they are forbidden in my country.
The Evo needs a stiffer sidewall when on stock size 235/45/17
I will try to contact the store and Yokohama together to get the AD08 Neovas, but I do not know if they will fix the problem
obs: Tried a lot of pressures from 28 to 35psi
The same corner I was used to turn at 140km/h with my Evo, 130Km/h with my Outlander V6 and now with Advan Sport installed no more than 100Km/h!!!
Old Aug 16, 2009 | 10:41 PM
heel2toe's Avatar
Im sorry you dont like the tires you purchased. Just curious as to why the A046 are forbidden in your country?
Old Aug 17, 2009 | 06:05 AM
k270kmh's Avatar
Yokohama policy
Old Aug 17, 2009 | 06:08 AM
k270kmh's Avatar
Today I looked to the tires to see/check if all the tires were facing outwards, in the correct position. Yes my friends, they are mounted perfectly. The problem is the soft sidewall.
Old Aug 17, 2009 | 07:18 AM
GTWORX.com's Avatar
The first 50 miles or so of a tire are really bad...but they get better. Still nowhere near what the original tires are like.
- Andrew
Old Aug 17, 2009 | 12:59 PM
Neal@tirerack's Avatar
+1. Give the tire a 1K miles or so to break in a bit before you get a real idea of it's handling. At full tread depth they will squirm quite a bit and tend to roll over if pushed. True with any new out of the box tire.
Old Aug 17, 2009 | 08:15 PM
k270kmh's Avatar
Do you think that AD08s are a better choice?
Btw, How do you explain that "flexing" feeling? (even on straights)
Have you ever driven an Evo with 235/45/17 Advan Sports?
Old Aug 17, 2009 | 09:05 PM
MitsuJDM's Avatar
Dunlop Direzza Z1*.... buy them, be happy.
Old Aug 18, 2009 | 04:31 PM
spoolinx's Avatar
I'm sure the AD08 will be a god choice. I'd love to have a set of them
Old Aug 19, 2009 | 12:53 PM
k270kmh's Avatar
My only option for now(up to november) is A048 in 255/40/17 size.
What do you guys think about this tire for an agresssive street/road use?
Thanks
Old Aug 20, 2009 | 04:26 AM
Biggy VIII's Avatar
I have been driving an evo with 245\40\17 Advan Sports for the whole season - 5\2 dd\ax. They do have a really soft sidewall and roll even with 45 psi )), they do flex and make evo feel unstable and sluggish on dry road a little bit. They become better at 2\3 thread, and start loosing grip on dry pavement after 2\5 of thread. I found 37 psi to be an optimal pressure for them.
The only reason i bought them is a really good grip on wet road.
AD08 are really good and have nothing in common with Advan Sports. A048 are even better, but only if you use them on dry track.
Old Aug 25, 2009 | 01:12 PM
k270kmh's Avatar
My worn A046 are back to the car today, I'm waiting the AD08 arrival in November...
I'm having a lot of work and expending a lot of money because of these Advan Sports... so be smart and never put this **** on your EVO!!!!
Old Sep 10, 2009 | 05:31 PM
Evoardo IX's Avatar
Just wanted to share my experience... I recently changed tires on my evo (from stock potenzas to falken azenis) and the handlig was HORRIBLE, but as the tire wears some it handles better and better, I think you should give the Advan sport another chance, wear them a little and then compare, keep in mind you are comparing the handling of a pretty worn tire to a brand new one = not a fair comparision.
Hope that helped, good luck.
Ed
