Brake bleeding problem
I am hoping if someone could help me with a brake bleeding problem. I was bleeding my brakes using the motive power bleeder and my right rear and left front calipers will not bleed. I opened up the valve and I saw some fluids making it way through the tube and into the bottle but after a few moments, it stopped flowing. Only happened on the calipers I mentioned above. The other two calipers were bleeding fine. Motive bleeder is set at 15psi.
Someone said that the Evo brake system is design based on "cross calipers". What this mean is that cross calipers(calipers across diagonally from each other) are on the same brake circuit for safety. So if there is an issue with both left front and right rear calipers, it may be a clogged in the ABS or wherever it gets distributed.
If this is the case, I'm trying to formulate ideas on what could cause the clog. I don't want to make a dumb remark but what could cause a clog in the brake system? When I think of a clog, I think of something physically like rocks, dirt, etc. But I don't think I have gotten anything into the brake system. Heck, there's a mesh filter in the brake reservoir. My other idea is that there is a very very large air bubble that is being stubborn to move. I think this is a silly idea but kind of make sense to me. For example, if you have a ball that is filled with air and try to push it into a pool of water, the ball will resist going into the water. So the same idea can be made in this situation if there is a huge air bubble that is big enough that will resist moving in any direction. I may need something with more pressure to pump the fluid out along with the air bubble. I don't think 15psi is enough. May have to use the brake pedal and pump the clog out of the system. Feel free to correct me as I'm trying to figure out if I have a small problem or a large problem on my hands
So, to summarize my problem. Cross calipers(left front and right rear) will not bleed. Motive bleeder is pressurized at 15psi. Other calipers are fine. The other option I could try is a 2 man bleeding procedure which I will try when I find the time.
Any help would be appreciated.
-Thanks
-Thanks
Take the bleeders out one at a time and see if fluid will come out of the inboard/outboard bank... this should confirm if there is a plug in your system...If there is, you should also check the cross over pipe connecting the banks together.
Also nothing beats a good o'l fashion 2 person bleed.
rob_d
27
May 2, 2016 09:23 PM
blknblubkrdude
May 1, 2015 02:49 PM
turboGarrett
10
Aug 7, 2011 02:32 PM
