Brakes Pulsing and random noises.
I've noticed that my steering wheel tends to shake more when I brake at higher speeds and it increases more when more pedal pressure is applied. I've been thinking it may be build up on the rotor, but there is one thing that makes me think other wise. It seems like I can hear something loose, or moving around a little bit when I am braking from around 20 mph to 0. Thats what makes me think its not build up on the rotor, but I could be wrong. Any ideas at what I should check/look at suspension wise or take the pads out and look at them? They seem to have a decent amount of life to them still. I'm kinda lost...
See the thing that makes me wonder is that it was more like of an overnight change. And I don't recall using the brakes hard at all. I mean sure I felt a little movement in the wheel when using the brakes at higher speeds before, but now at higher speeds its just ridiculous. Also I can hear something moving around almost every time when I am using the brakes at lower speeds like coming to a stop in a parkinglot. I really do think something is loose.
They turned them, not warrantied because they are a wear item, but whatever. I was surprised how much sheot those warped rotors caused.
If they start to warp again, I'll just buy some better ones.
I guess the guy that worked on my car is friends with fathouse.
funks
58
Dec 20, 2012 11:34 AM
lancerhero
Jan 12, 2008 04:21 PM
