First Tire and Pad Choice
Old Sep 14, 2009 | 05:21 PM
boost247's Avatar
Originally Posted by SmikeEvo
Other way around, shorter tire, less gearing to use. Its why I ran a larger series (245/45) to stretch out 2nd more for AX.
I was thinking better=better acceleration. You're thinking better=higher top speed. I suppose it depends on the course.
Also, I was the guy in the Black MR at the MSU event a couple weeks back. It was good to meet you (even if it was brief).
Thoe99's Avatar
Originally Posted by boost247
As a bonus, I can't seem to overheat the Z1* during autocross use. They seem to relish autocross levels of heat. FWIW, I'd go with the shorter, stiffer sidewall (245/40/17), it also gives you slightly better gearing for autocross. Note: your speedometer will read ~2.5% higher than actual speed.
Here's a link to a great wheel/tire size calculator: Here
That's cuz you live in MI Here in Orlando, with our top drivers running the Dunlops, it was rare to see us hit our fastest lap on the last lap. Even when I would stay for 'fun runs' after the event, the tires just got too hot for me to beat my competition times...at least in the summer months, which is almost year round
Old Sep 14, 2009 | 05:24 PM
boost247's Avatar
True. "Summer" for us is a 2 week period at the end of July.
Old Sep 14, 2009 | 06:40 PM
Smike's Avatar
Hey hey. Good times there.
Old Sep 15, 2009 | 06:43 AM
eric06ix's Avatar
I've done 2 track days in my Evo, and I used Hankook RS-2s in size 245-45-17s. They don't get greasy until the end of the session, but still have good grip. I'm using DS2500s with Motul RBF600 fluid and Works lines, and I still get some fade with hard, late braking. If I brake early, the pads are fine, but I'm used to braking late with my other car, and that caused a few pucker moments. For a car that is mostly street with some autocross, the DS2500s are fine. The lines really firm the pedal up though. I the first track day with stock everything, and it was scary.
Old Sep 15, 2009 | 07:06 AM
Smike's Avatar
I really do not recommend running the DS2500s on the track. The MOT is 1000F, and as you saw, pretty easy to overheat/fade after some hot laps.
Old Sep 15, 2009 | 12:30 PM
rawkus's Avatar
Originally Posted by rush63
The OP's purpose for the pads are "street, occasional AutoX(1-2 times a year), and hopefully HPDE some day". Would you recommend ET800 for the street driving? I'm also in the market for pads for street and occasional HPDE. ET500 and ET700 are among my choices. I know I should be using different pads for street and track...but, oh well.
I would say ET800s would be great for street or maybe stick with the ET700s. They are just a little noisy, but that doesn't bother me at all. I don't think the ET800s are great for the track. I ate through them with 4 track days.
Old Sep 15, 2009 | 12:37 PM
Thoe99's Avatar
How long does it take to heat up the ET800s? Is it quick enough to do an autocross with (where pads need to heat up within a couple hard braking turns)?
Old Sep 15, 2009 | 12:46 PM
rawkus's Avatar
They grab pretty hard right out of the bag. I had to be pretty firm on the pedal pressure though.
Dan
Old Sep 15, 2009 | 01:28 PM
Thoe99's Avatar
Have you used the ET500? I'm using that now and am wondering how they bite initially, compared to those. I need an upgrade.
Old Sep 16, 2009 | 06:38 AM
Smike's Avatar
I ran the ET500s when they first came out. I did not like them. Lots of pad transfer. RB's customer service was less than great. So I went back to GS5s.
Old Sep 16, 2009 | 06:54 AM
rawkus's Avatar
I'm afraid I have only used the ET800s. I have heard good things about the ET700s though.
As far as customer service, I have always purchased through MAPerformance and not had any issues.
Dan
Smike
628
Oct 27, 2024 04:39 AM
Smike
63
Apr 29, 2019 07:27 AM
Kracka
22
Aug 17, 2016 09:31 AM
pcguru2000
Lancer Troubleshooting
May 10, 2013 06:43 AM
Quick Reply: First Tire and Pad Choice
