Cheap assed steel rims?
apparently no one makes steel wheels that fit an EVO...
hopefully that will change at some point in the near future. I'm sure they'd sell like hotcakes if someone did crank some out at $90 or less a pop. A steel 16x7 (or 17x7 if they couldnt make a 16" wheel fit over the brakes) would be great for winter use.
Alot of guys are choosing to use stock 17x8s with winter specific tires for this winter (and maybe future winters) and plan to buy some nice aftermarket 17x8, 17x9, 18x9, etc, rims in the spring for general spring-summer-fall EVO usage from that point forward.
I'm doing this, gonna get Pirelli 210s on the stock 17x8s for winter use, then plan to pick up some 17x9 gold/bronze/black wheels with sticky Nittos in February/March for spring-summer-fall use.
hope that helps
hope that helps
My view is why spend $200 a pop on wheels that will see harsh winter conditions? Does anyone sell steel's the right size and offset for the EVO?
I had been thinking along the same lines.
Rims like the base model (RS I believe) Japanese Version 7 had. I think they would make for a perfect winter wheel/tire set-up. I wonder if there would be a feasable way to get these rims from Japan if enough people wanted them?
Venders...? Any ideas?
Re: Cheap assed steel rims?
That might be fine, if you live in Frostbite Falls and never see a bare road all winter.
But most of us need a mix of snow and dry road handling.
That means fitting rims over the stock brakes. A steel rim that would fit would weigh a ton. That's a lot more unsprung weight than the suspension was designed for. One consequence would be that the tires wouldn't stay glued to the surface as well. So your tires would skip off of irregular surfaces -- like hard-pack snow, plowed roads with dry spots, or poorly paved roads. And if your tires aren't on the ground, you're an unguided missile -- pure ballistic. I don't know what it would do to your shocks over time.
So, to answer your question, the reason to spend money on winter rims is handling.
Properly shod, the EVO should be an all-season performance car. Winter alloys aren't as cheap as steelies. So what? The EVO isn't as cheap as a Yugo.
As they say on the track: it's a matter of seconds per dollar.
UnholyMaggot
Sep 30, 2015 09:43 AM
VanLancer
Dec 3, 2013 12:38 PM
