uneven tire wear
Yes, the uneven tire wear can probably be corrected through alignment.
Please elaborate on what you mean by funny wear on the outside edge, and is it all four tires, just the fronts, just the rears, or just a single tire? Too much wear on the outside edge could be caused by incorrect camber setting, by too much toe-in, by underinflation of the tires, or simply by too much hard cornering.
How do the inside edges of the tires look?
Do you have one edge of the tread blocks which has a feathered edge? Kind of like a tiny little "spoiler" on the edge of the tread block?
If so, and if it's most pronounced on the outside edge of the front tires, you've got too much front toe-in. The factory spec is for zero toe-in at the front, if I'm not mistaken.
Doc Davey
10
Apr 15, 2012 11:07 AM
faraz
15
Jun 27, 2008 09:29 AM
twinturbozs
27
Nov 20, 2006 04:06 PM
teknotikal
15
Aug 2, 2003 10:20 PM
