Need brake pads for my evo
I just did my 15K mile service at the dealer and they said that my brake pads are almost worn out. Sure enough they look like they are ready for replacement. I was just wondering what my options were? I know there is obviously the stock Brembos, and the Ferodos. Which is better? I don't think I was to look into any specialized brands like EBC Greenstuff, since I had a compatibility problem with the rotors on my previous car. Any info on what my options are and how well they performance would be appreciated.
A friend of mine runs the redstuff pads and seems happy with them, except for the noise. His wife is embarrassed to drive the car near schools because they're so loud before they warm up. And before anyone comes up with some derogatory wife comments, she's a track fiend as well.. I'd stick with the stock brembos, they were only 80 bucks at my dealer and mine are holding up great despite going through 3 track days with them and 13K miles. You must be a maniac to wear out your pads at 15K!
I really don't abuse them that much. At least I didn't think so until now. I do a lot of freeway racing. Being that I live in SoCal, I am usually on the brakes pretty quickly on the freeway because of all the traffic. Yeah I guess I should stick with the factory ones to be safe. My experience on my last car definitely taught me to stick with what I know. Who is a good vendor for brembo pads? My dealer tried to rip me off by telling me that fronts and rears were about $210 per set. They are dreaming if they think I am going to pay $420 for brake pads. Also, do you guys know of a good shop around LA that I can use for the labor? I guess I could go to Roadracemotorsport or the dealer. I didn't ask the dealer how much they charge, but it's got to be more than what a regular tuning shop charges.
Get Ferodos! EBC sucks because they will eat through your rotors It happened to me on an Aem upgrade. I have used many upgrade setups with pads in my life and by far crossdrilled and slotted brembos with Ferodo pads will give the most confidence at the highest speeds and the hottest temperature, braking as hard as you want
Noone who has tried both can tell me different.
there's a company in england i think that makes pads as well.
the brand is called 'Mintex'
I have them on my evo7 and to tell you the truth, you could never tell the difference between the mintex..and the stock pads.
they hold reallllll good!
price is like 80 pounds.
Those pads from MachV are the oem's. The pads that comes with our cars are not made by brembo, they do not make pads, those pads are made by Galfer. To be honest, I will take the ebc's anyday than the galfers.
One of the reason that I changed to the ebc was that on the oem's the initial bite is horrible and also with the ebc there is almost no brake dust.
For Fast Road use :
Carbotech Bobcats
http://www.carbotecheng.com/prod-ct-compounds.htm
OR
Ferodo DS2500 compound.
edit : left out the bobcats due to posting error. Many on this site have the Carbotechs and love 'em!!
Carbotech Bobcats
OR
Checkout the Carbotech ones if you plan on tracking quite a bit...
http://www.carbotecheng.com/appguide...mitsubishi.htm
Ferodo ds 2500 are just slightly better than the standard ones.
Ferodo ds 3000 are very good, very high friction pads, but as there are a lot of metal particles they leave a lot of dirt on the wheels.
Pagid rs 14 are about the same as ferodo ds 3000, but they are organic, so they leave less dust on the wheels... They brake much better than standard pads.
Pagid rs 15 should be like the rs 14, but even more agressive... if you don't have road legal semi slick tyres like a048r, you ll probably lock the wheels easely.
The blue pagids (rs 4 2 4???) are less aggressive than the rs 14 and 15, more progressive for wet road or gravel, but still slightly better than ferodo ds 2500.
rs 19 are the endurance pads, they are less aggressive than rs 14, but should work very well at high temperature and last very long.
BTW, with rs 14, 15 or ds 3000 you will get much more braking power.
***** B R E M B O *****
Brembo MR407376 Brake pad set, F Brembo E5/8 (A) OEM
Brembo MR407391 Brake pad set, R Brembo E5/8 (A) OEM
***** F E R O D O *****
FCP1334H F FERODO DS2500 17" TARMAC/STREET
FCP1282H R FERODO DS2500 17" TARMAC/STREET
FCP765H F FERODO DS2500 only (EVO IV)
FCP1280H R FERODO DS2500 only (EVO IV)
FCP1334R F PAD FERODO DS3000 17" TARMAC
FCP1282R R PAD FERODO DS3000 17" TARMAC
DS2000 Working Temp Celcius (100 - 600)
DS3000 Working Temp Celcius (100 - 750) CF .62
4003 Working Temp Celcius (100 - 750)
DS3000+ Coefficient of friction > .62
***** P A G I D *****
U1591RS14 F BLACK PAGID RS4-2 17" (RS14) TARMAC
U4507RS14 R BLACK PAGID PG 17" (RS14) TARMAC
RS 4-2 Working Temp Celcius (400-700) Coefficient of friction .45
rs 4-4 Working Temp Celcius (350 - 650)
black Working Temp Celcius (300 - 700)
***** M I N T E X *****
1144 Working Temp Celcius (50 - 500)
1155
1166 Working Temp Celcius (100 - 700)
f4r (N/A)
***** P F C *****
pfc 5183 Working Temp Celcius (300 - 750)
pfc 5193 Working Temp Celcius (200 - 750)
* pfc pads can hold 800 degrees for a short period - Info by advevo!
***** H A W K *****
Blue racing - coefficient of friction .55 and
Working Temp F (600-1400 degrees F).
Black - coefficient of friction .49
Working Temp (400-1100 degrees F).
Gray pads (require aluminum rotors) - coefficient of friction .42
Working Temp (ambient-700 F)
Street HP - coefficient of friction .44
Working Temp (100-900 F)
1155
f4r (N/A)
***** P F C *****
***** H A W K *****
