lightest 17's for under $350
Originally posted by Nyc_Ryc
Enkei RPO2's. I am getting mine - 17x9, 35mm offset, for about $200/ea. You can also get it in 17x8 w/ 40mm offset. It weighs 17.7# in 9" or 17.2# in 8". 17x9 is nice b/c it fits and it lets you plant the tire on the ground better, particularly a larger tire like the 255/40/17 (which looks great on my car).
Lighter but also a little more expensive is the Enkei RPF1, which weighs only 15.9# in 17x8.
See both wheels at: http://www.enkei.com/High%20Performance.html
Enkeis are available from a lot of dealers, and probably some of the vendors on this site.
jbrennen question on your RPF1's that you use at the track. Are those the stock size tires, becuase in that pick they look like a larger side wall. Although they are not my favorite looks wise, they are my favorite for the price/weight. Under $250 a wheel including shipping is hard to beat at 15.5 lbs a wheel. So I will need to throw in an extra $80+$70 for caps and lug nuts. I am still debating but these might be the ones........
They are also Hoosiers with a very stiff sidewall, inflated to about 45 PSI, with essentially no visible tread. So the picture is perhaps a bit deceiving.
FS[Northeast]: NY: Evo VIII Unorthodox Racing Adjustable Cam Gears
MisUnderStood
12
Mar 12, 2017 08:33 AM
SS RX7 r2
108
Apr 21, 2006 01:58 PM
BaLListic_EVO
17
Sep 2, 2004 12:37 AM
boostedwrx
27
Jul 9, 2003 06:37 AM
