swift spring install
You need a compressor to take the stock springs off, but you can put the rear springs on without a compressor. The fronts maybe, but just use a compressor to be safe.
A guy who works beside me used to lay the strut on the ground, put his foot on the base of the strut, point the top away from everything, and just zip the top nut off with an impact gun. Easy, fast and amusing.... but dangerous
![Stick Out Tongue](https://www.evolutionm.net/forums/images/smilies/tongue.gif)
As you loosen the rear top nut you will feel the spring come loose, the front however will have a ton of pressure on it. Compress it enough to take the pressure off, then remove the nut. *Make sure you mark 1 of the top bolts and it's position on the car so when you reinstall the assembly it goes back in the same exact way.
FS[SouthEast]: evo 9 sturs w swift springs
mikgsxx
May 28, 2015 04:23 AM
FS[SouthEast]: swift spec r springs
whatever210
Jul 3, 2014 08:45 AM
Speed MR 857
Apr 26, 2010 08:48 AM
aboogabooga
25
Nov 23, 2009 03:02 PM
