Rear brake adjustment
I have been having some troubles with my rear brakes.
A few months ago they starting squealing bad, the rotors had been grooved by what looked like uneven pad wear.
I resurfaced the rotors and installed new pads. Now when I go out to log 3rd gears pulls, the brakes will squeal bad as i am slowing down. I am wondering if the pads are rubbing the rotor and heating them up? Or maybe coming loose somehow?
If anyone has thoughts please share.
![Smilie](https://www.evolutionm.net/forums/images/smilies/smile.gif)
I am using porterfield rs-4 pads.
What should i check on the calipers?
Also, just to be clear. I only get the squealing after doing a hard 3rd gear pull. No problems at last weekends' auto-x or during/after highway driving.
hmm.
So your thinking that because my pads are relatively cold, that when I apply the brakes they aren't sticking properly. This causes them to vibrate and hence the noise?
Another contributing factor could be that my rotors are spinning pretty fast.
I buy this, still am concerned that something could be wrong with my brake though![Frown](https://www.evolutionm.net/forums/images/smilies/frown.gif)
thanks!
thanks!
Go_Lancer_Go
Apr 5, 2009 11:46 AM
