Help! My Alignment Specs are they Screwed up.
facepalm - you do not have a Lancer for getting an alignment. That right there is telling me they didn't know what they were doing.
You have the left camber bolt at the -2 setting and the right side at the -1 setting. Fix that.
You have more toe out on the rear left. Do not want.
They did make improvments, but they're half-assed improvments. And your car is not a Lancer. That looks like the print out that Hunter machines print, and I've aligned my own Evo on one myself and there should be a seperate selection for "Lancer Evolution".
I have noticed that if camber is more on one side then the other there is sometimes a pull to the side with less camber. Toe looks okay you usually cant feel anything under .1*. Also make sure all tire pressures are equal.
s2KMR
26
Mar 29, 2007 07:35 PM
Mooshu1221
12
Feb 2, 2005 05:14 PM
BIGWING
Sep 9, 2003 08:05 AM
Thoe99
16
Aug 12, 2003 01:18 PM
