Brake squeaking noise
Alright so this have been happening lately on my car and its starting to get annoying. From what im hearing there is a squeaking noise coming from the passenger side front wheel. I dont know if its brake dust thats making it squeak or its the brakes or the rotor. But It's really bothering me. Every time i break it gets louder and i everytime i drive it gets a little bit lower but it still squeaks. Do you guys know whats wrong?
ugh i forgot what pads they were but i got them from autozone. Spent about 100 bucks on them. But the rotors are the stock ones and stock brembos. I have about 1000 miles on the brake pads and the rotors and the brembos are 60,000 miles on them now.
-Craig
I doubt Autozone pads would squeal. They may not work as well as OEM or some after market pads out there, but if installed correctly they should not squeal.
Did you just do a pad slap? Did you cut the rotors? Not that there is many, but did you lube all the contact points?
Yup. i lube the brake pad where the caliper piston pushes the brake pads. Oh and i installed that new metal piece on top of the brake pad where the two little metal sticks right in.
TxFAkuma
45
Feb 24, 2017 05:19 AM
Gurvir19
26
Nov 7, 2010 03:32 AM
LooneyToon
May 11, 2009 05:25 AM
